IM C300 locking up
Re: IM C300 locking up
"ALL port LEDs were flashing high speed in sync" is called jabber. Usually it is caused by a bad interface card but 2 ports connected together can have the switch or more often a hub talking to itself and not knowing what port to respond to. Doesn't happen immediately when connected unless there already is traffic. But as soon as a packet hit, a hub sends it back out on all ports and with the looped back cable it keeps looping. Usually with a switch it would indicate a failed switch as a switch does not usually broadcast traffic on all ports.
The customer had a 100 MB/s switch locked at 100 MB/s, and I connected my measly little 10 MB/s hub to it as I needed another port to do some testing. (Yes, it was hub, not a switch.)
Lots of blinky lights on my poor little hub.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Ive had some time off over the festive period and as yet not returned to the issue.
The suspect IM C300 is here in the workshop, no issues as yet, printing fine from three diffrent pc's and all printing PDFs via Adobe Reader and also word docs.
As I said before - spooky as the loan MP C307 we supplied them as a temp messure works fine.
Will let you know if we fine out whats causing it.
DaveComment
Quick update on this issue
went to customer today with a spare IM C300, before we took it we checked that everything was the same in F/W and printer settings.
The customer had no issues! - Dame was hoping for a similar fault to point to there I.T
Lets see what Ricoh have to say about it, Possibly expensive board replacements!Comment
Opps that's lame - I feel your pain
Me beeing lazy I'd probably just swapped the controllerboards among both machines and save myself the time arguing with ricoh.
It's still likely that something is off "on site" but the controller board revision of your test machine don't care about that for unknown reasons.
It's also unlikely that the controller board from that customer will do trouble in other enviroments since you
already testet it.Comment
UPDATE
Been comunicating with Ricoh. SP5801-008 was mentioned. as the machine is in our workshop that will not show me if it worked but worth keeping that in my toolbag for other jobs in the future.
Looks like the this issue has been passed up the chain at Ricoh.Comment
We are back to the customer today with another IM C300 for them to have to keep due to the hastle.
The orig machine will now sit in our workshop waiting for Ricohs responce, I wont be holding my breath on that one.
Thanks all
will update on any excitement!Comment
Thanks MIKON
Its not when it comes out of sleep mode.
A few Excel jobs are printed very quickly together and about the 3/4 job it locks up, same with PDFs
So no time to go into sleep mode.
I did extend the timer to 60mins to make sure it doesnt go to sleep, still same issue.
Still pondering
Thanks all
Dave wComment
Thanks MIKON
Still pondering
Thanks all
Dave wComment
So the same model replacement machine is working good on the customer network?Comment
Hi
we removed the printer from customer. It sat in the workshop for months with no issues.
The customer I.T were trained in using correct driver and using adobe reader. - no more issues from customer with replacement machine.
We have rolled out the original machine to another user and no issues.
No logic to what was happening and nobody was owning up to causing the issue.
all good now.Comment
