sp c360 printer sc 332-01
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. I'm not very familiar with these printers, and the code indicates a toner supply problem with black. The smc indicates that this has been an intermittent issue since October. A reboot clears the code. I have a PCU coming to install soon, and I just wondered if any of you have run into this issue on this model. Thanks, Mika.
    NEVER ASSUME ANYTHING
  • Polo-022
    • Sep 2007
    • 486
    Re: sp c360 printer sc 332-01
    Sp c362dnw printer - sc-332-01
    Take a look here Mikado...
    • luca72
      • Oct 2017
      • 1791
      hi Mika, try to verify that the toner cartridge, when inserted with its rocking movement, really reveals the small toner input cover on the pcu, the same code happened to me last week, on another model, it was the plastic mold of the cartridge itself (I think) did not mate well ... in my that case i could change the springs with 2 harder ones that push the gr.development against the cartridge, in any case, if the window is on the pcu, (as in my case) eventually you can also eliminate it the input cover, so much so that you don't have to put the machine upside down...lol
      "I'll be back"
