ricoh mp 2852sp - blocked
  • tullio
    • Feb 2012
    • 268
    ricoh mp2852sp blocked . the sheet is not there. unplugged, same problem. help thanks.
    WhatsApp Image 2022-12-19 at 21.11.40.jpg WhatsApp Image 2022-12-19 at 21.11.41.jpg remove paper from tray one
  • copyaction
    • Oct 2007
    • 991
    Re: ricoh mp 2852sp - blocked
    Look at the area where the paper just exits from the machine. You should see a small black plastic arm. Make sure it has not become stuck in the up position or knocked out of place.
    • tullio
      • Feb 2012
      • 268
      [QUOTE=copyaction;2273385] Osserva l'area in cui la carta esce appena dalla macchina. Dovresti vedere un piccolo braccio di plastica nera. Assicurati che non si sia incastrato nella posizione sollevata o sia fuori posto. [/CITAZIONE]
      done. same problem.
        • 37533
        You post does not mention what the jam code, Jxxx, and you pictures are of very bad quality. That makes it almost impossible to determine exactly what the problem is with your machine.
        • copyaction
          • Oct 2007
          • 991
          Yes those pictures are unreadable.
          • KeviM
            • Oct 2019
            • 324
            [ATTACH=CONFIG]55954[/ATTACH] [ATTACH=CONFIG]55955[/ATTACH] remove paper from tray one
            1} Agreed with Slimslob and the other engineers, your pictures are really unclear. If we can't see anything it makes it difficult for us to help you
            2) From your description :
            Copyaction is correct, check for the small black arm. Make sure its out and can freely move up and down.
            3) if you remove the small front white and black cover (about 6 inches by 6 inches) where the paper comes out you will be able to see where the end of that arm makes a sensor. Next to that sensor is another identical sensor. As a temporary measure you can swap to 2 sensors. This should help resolve the issue and give you time to order some new sensors.
            All the best friend
            • tullio
              • Feb 2012
              • 268
              Thanks, I fixed it. it was the sensor. thank you.
              • luca72
                • Oct 2017
                • 1784
                unfortunately, our friend Tullio, as a photographer is a landslide .... maybe he does it on purpose to make us commit more ... LOL
                "I'll be back"
