Ricoh MPC5503 (K) Dryum & Developer Replacement
  • adamcopiercali
    • Aug 2012
    • 88
    Hoping for some help. Any precautions/procedures for replacing the black drum & developer on a Ricoh MPC5503? Any SP resets before or prior? Filling in for a colleague and I am not too familiar with these machines. Any help is greatly appreciated.
  • copier tech
    • 8144
    Re: Ricoh MPC5503 (K) Dryum & Developer Replacement
    Since you are replacing the PCU & developer unit at the same time there is no SP counter to reset replacing the dev unit will also reset the PCU PM counter.
    Remember to the release the lube bar spring on the PCU (instructions will be in the box)
    I would suggest you have the service manual to hand as these parts are rather expensive.
    • adamcopiercali
      • Aug 2012
      • 88
      Thanks for the information. The Developer and Drum unit came assembled. Upon installation I got a SC324-1 Error. Any ideas? The machine was not previously showing this error prior to the new drum & developer install.
        • 37489
        something is binding in the development unit causing the development motor to be unable to turn at full speed.
        • anothertech
          • 1769
          Take the PCDU out, hold in level and shake in side to side, then try to turn the developer by hand to free it up.
          • sandmanmac
            • 3981
            And it works ok again with the old unit re-installed?
            Were these brand new Genuine Ricoh Units, or something that's been rebuilt/ serviced?
            I'd be surprised if a NIB unit would produce that code
