Final Call about the board ISSUE:. Is it the Board really physically damaged, Or need high advance software-level knowledge to restore the Board in a good order?
I guess it doesn't matter if it's hardware or software failure, either way the board still gets replaced.
but when you install a UPS battery backup. the customer thinks 1. they can plug anything they want to into it. 2. they also think they can run for a bit on the battery. a copier is gonna drain the power in the battery faster than you can blink.
