Aficio 2027
  • RSCA
    • Jul 2008
    • 112
    Aficio 2027
    This is the Gestetner version DSM627. 324K. Recently replaced the PCU. Customer complained about washed out printed pictures. If I run a sky shot there is white lines front to back. No set pattern but bad enough to definitely affect picture quality. Line copy is ok, not enought solids. I replace the PCU again. Much better but still there. This machine is in a woodworking shop. Lots of sawdust. Could this be laser?
  • totoro
    • 568
    Have you cleaned the optics?
    Totoro
    • RSCA
      • Jul 2008
      • 112
      Yes, especially in this environment it's an automatic.
      • fitsy.13
        senior tech
        • 64
        try cleaning the slit glass infront of the laser unit they are forever getting dirty and causing the copy quality to be washed out
        • RSCA
          • Jul 2008
          • 112
          Did that also. In this model you have to remove 1 screw on a small plastic cover to access the glass.
          • fitsy.13
            senior tech
            • 64
            what state is the transfer is it covered in muck
            • RSCA
              • Jul 2008
              • 112
              I had that same thought so I vacuumed the roller. It made no difference. If it had improved somewhat I would have gone ahead and replaced but since there was no change I'm pretty sure it's something else.
              • copytechman
                • Nov 2008
                • 947
                Is this anything like the transfer roller in an aficio 220/270 series? If so, random white marks are one sign that the xfer roller is on it's way out.
                Vacuuming one doesnt help, it's conductivity decreases over time.
                Regards!
                A.
                • Jomama46
                  • 2900
                  Print a checkered or other solid print from the memory to eliminate the scanner
                  sigpic
                  A+; Network +; PDI+
                  • rthonpm
                    • Aug 2007
                    • 2859
                    It sounds like you definitely need a new transfer roller. The latest and greatest part number is B2033831. When this goes, the first problems start showing up in anything with a halftone pattern, like pictures.
                    • totoro
                      • 568
                      Sorry it took so long I answered just before I left for work. I agree with the others, transfer roller.
                      Totoro
