Ricoh C5200 Faded Printing on Y and M
  • nysamara
    • Apr 2016
    • 58
    Hi all! I purchased a used Ricoh c5200. It was never turned on, but when I finished installing it, it failed dems. I replaced the developer for all colors however it continue failing DEMS and Fulll Music. I was able to identify that it prints very well the K and C, but I have issues with the Y and M. I swapped the Y PDCU with the C PDCU and it printed very well the Yellow on the C location but not the Cyan on the Yellow location. Any suggestion? I was thinking that it may be a problem with the laser unit of Y and M which is the same. I also tried cleaning the laser glass with the provided tool with no success. I will appreciate if you can help me.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh C5200 Faded Printing on Y and M
    What sort of mileage does this thing have on it?
    Hit it.
    • nysamara
      • Apr 2016
      • 58
      Probably 100 copies, It was a machine that was never used. It was stores in a non controlled room and transportation was not the best.
      • TonerMunkeh
        Professional Moron
        • 3865
        Judging by the fault finding you have done by swapping the PCDU's over, it only really leaves two things, laser or ITB. It could be the Y and M ITB drum bias rollers are sticking down slightly.
        Hit it.
        • nysamara
          • Apr 2016
          • 58
          I was able to resolve issue... It was the laser power supply cable that was disconnected. Apparently that happened during transportation.
          • copier tech
            • 8210
            That was a good find, you suspected the laser when you first had this issue. However it can't have been the 'laser power supply cable' I would have expected an error code.
