MP305+ randomly not pulling from ARDF, reads from glass. Sensors OK.
  • mrwho
    Major Asshole!
    • 4299
    [Misc] MP305+ randomly not pulling from ARDF, reads from glass. Sensors OK.
    Good morning folks.
    I've got a Ricoh MP305+ that usually (but not always) will not pull the original from the ARDF, reading from the platen glass instead.
    What I managed to gather so far:
    - All the ardf sensors test OK on input check (original, registration, cover and lift);
    - The harness between the ardf and the bicu was replaced;
    - The machine beeps when inserting the original;
    - The lift sensor changes state when lowering the ardf;
    - It's the second ardf we test on this machine for this problem;
    - Sometimes out of the blue it will pull the original from the ardf;
    - Most of the times after rebooting the machine it will pull the original.
    I believe a colleague already updated the firmware, but it will be done again just for kicks.
    Any suggestions are welcome.
    Thanks.
    Mascan42
    Ibid
  • KeviM
    • Oct 2019
    • 324
    Re: MP305+ randomly not pulling from ARDF, reads from glass. Sensors OK.
    I would say change the document feeder lift sensor even if it is reading.
    Next I would look at the ADF board.
    Lastly BICU.
    All the best friend
    • eddy out
      • Oct 2016
      • 359
      Originally posted by mrwho
      Good morning folks.
      Thanks.
      The problem remained after swapping ardf?
      • mrwho
        Major Asshole!
        • 4299
        Yes.
        That list is a rundown of everything done by me and my colleagues (it's one of those machine problems where everyone takes a shot at it)...
        Mascan42
        Ibid
          • 37508
          Yes.
          Sounds like either corrupt firmware or a controller board problem. Try re-flashing all the firmware.
          • MIGUELMARCHENA
            • Feb 2018
            • 195
            It happened to me, i updated firmware, i checked the same and it was bicu
            • mrwho
              Major Asshole!
              • 4299
              Thank you. Passed this info onto my colleague, I'll let you know once he tells me how it went.
              Mascan42
              Ibid
