Ricoh/Microsoft automatically add printer
  • DBT
    • Jul 2011
    • 24
    Does anyone have an effective way to disable the Ricoh machine to be found by Microsoft. The driver Microsoft adds seems to be very problematic.from the settings I usually disable all the WSD in ip config and security. Maybe something with IPP. Please let me know if you have a process for this.
    • 37628
    Re: Ricoh/Microsoft automatically add printer
    It is a function of Windows called Network Discovery and you can turn it off. Exact steps depend on the exact Windows version you are using, and for Windows 11, which build you are using. Here is a link for Windows 11. Option 1 is for Build 22509.1011 and later releases. Option 2 is for older releases. It has to be done on each computer. On a domain you might also be able to turn it off with Active Directory's group policy editor.
    • DBT
      • Jul 2011
      • 24
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        You forgot the link.
          • 37628
          I will try again.The website is Elevenfirum in case it doesn't stick.
          Attention Required! | Cloudflare
            • 37628
            Then in WIM you need to turn off every network protocol that you are not going to use. That is pretty much everything but TCP/IP. Bear in mind that WSD is a subset of TCP/IP so computers will still be able to find the printer and might still assign it to the WSD port but won't be able to print using that protocol. Also Windows will still assign the Ricoh type driver even if it uses IP printing.
            • anothertech
              • 1771
              The best thing you can do is update the Ricoh firmware and keep it up to date moving forward. There have been many recent firmware updates that help with printing from the drivers windows likes to install.
              • copier tech
                • 8221
                Originally posted by DBT
                Hello Slimslob
                thanks for the input, I’m looking for more of a setting on the Ricoh. This way it will not see it and/or not print.
                I have had good results disabling these settings in Network Security.
                • copier tech
                  • 8221
                  Trouble is with turning off network discovery it will disable file sharing.
                  • rthonpm
                    • Aug 2007
                    • 2860
                    Network discovery is a dead feature unless you still have SMB1 enabled, which no-one should still have enabled for any reason.
                    The solution is to disable WSD on the device so it doesn't advertise its features on the network, making sure to disable all of the features. This should ideally be done before the machine ever gets to the client.
                    Sent from my Pixel 6 Pro using Tapatalk
                      • 37628
                      Have you actually gone in PC Settings - Network & internet - Advanced network settings -Advanced sharing settings? On the current W11 build Network Discovery and File and printer sharing are two separate switches. One makes your PC capable of AUTOMATICALLY finding devices, the other is a manual operation.
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        As others have suggested...turn off WSD and IPP via the WIM.
                        • brodiescomics
                          • Mar 2012
                          • 31
                          Along with disablinig WSD in the WIM, also disable IPP Port 631 - It kills Airprint, but will also kill the auto-installation of IPP Port.
                          • JaosnG22
                            • Oct 2023
                            • 1
                            [ATTACH=CONFIG]56867[/ATTACH]
                            This did not work for me.
                            WHen i disabled these protocols. i was still able to see the printer when i click on "Add Device"
                            its still Discoverable
                              • 37628
                              Disabling those protocols does not hide the device. It merely prevents Windows from using one of them for the device.
