Mp c3004 ex
  • luis_p712
    • Jun 2014
    • 9
    Mp c3004 ex
    Hello, any scope with this problem of accumulation of development in the middle. check that there are no obstructions but there is nothing. Thank you very much in advance.
  • GIUBOSS
    • 1437
    Re: Mp c3004 ex
    Have you tried manually rotating the magnetic roller? Is this a new or refurbished unit?
    • luis_p712
      • Jun 2014
      • 9
      Re: Mp c3004 ex
      Yes, turning manually does not present a problem. only when working
      • GIUBOSS
        • 1437
        Re: Mp c3004 ex
        Is this a new or refurbished unit? The problem is in the unit
        • davel
          • Oct 2011
          • 1108
          Re: Mp c3004 ex
          If PM count for this unit is over recommended just replace unit.
          • tjvincent
            • 280
            Re: Mp c3004 ex
            See bulletin 034, order a new development cover sheet, PN# M0AJ3138
            • 8T2
              • Aug 2015
              • 257
              Re: Mp c3004 ex
              i just grab the top plastic cover in the centre where the developer is gathering and pull it up and away from mag roller for a few seconds.
              these pcdu's are heavy and that cover deforms easily while handling it if you're not careful
              Sent from my SM-A305F using Tapatalk
