IM 350 Blocked (Authentification)
  • Exodia-P4
    • Jan 2023
    • 135
    Hello everybody
    I bought an IM 350 the last week. When I start it, a message appear : "CIRATO AUTHENTIFICATION" (with NFC cards I think) but no lector and no card...
    I try to uninstall all the appli "Cirato" on the SOP but there is an extended function whitch is install on the copier but I can not uninstall the function because the copier takes a long time to display and disconnect from the Admin mode...
    Have you an idea how I can reset the machine ? I already try an RAM clear (I save in 5-824 before in cas of) but its same...
    Thank you
  • GIUBOSS
    • 1437
    Re: IM 350 Blocked (Authentification)
    Originally posted by Exodia-P4
    Hello everybody
    Thank you
    You should look for the birth certificate sheet first and then reset / memory clear.
    • Exodia-P4
      • Jan 2023
      • 135
      I just find the solution. I reset the copier by the administrators tool and it's ok. It takes +/-3 hours
