FUSER RICOH MP C2003 -
  • tullio
    • Feb 2012
    • 268
    Ricoh mp c2003 fuser unit does it work in the ricoh mp c3003 ?
    Thank you
  • Daniel_B81
    • Jan 2019
    • 41
    Re: FUSER RICOH MP C2003 -
    Different part number at least, not sure if there is a way to modify it to fit.
    2003= D1764014
    3003= D1464062
    That's 220V EU-fusers that is.
    Noticed that the whole fuser assembly was near twice as expensive for the 2003 compared to the 3003 which i find very weird
    • 8T2
      • Aug 2015
      • 257
      under correction but I think the 3003 will work in a 2003 but not the other way round. 3003 has higher wattage lamps so the 2003 fuser throws warm up errors if used in 3003
      Sent from my SM-A305F using Tapatalk
      • Gift
        • Mar 2011
        • 2457
        +1
          • 37052
          Different sleeve. Probably lower wattage lamps in the 2003.
          • bategoiko
            • Dec 2010
            • 17
            The fuser sleeve and fuser lamps are the same in MPC2003 and MPC3003. Only in MPC4503 fuser lamps are with higher wattage.
            You can use the whole fusing unit from MPC2003 to MPC3003 with just swapping the lower covers of the units.
            • Gift
              • Mar 2011
              • 2457
              Are you shure? P/N for sleeve assy are different, too - wattage "could be" the same tough. I can't quickly find that info in service manual or 3D parts guide.
              • copyaction
                • Oct 2007
                • 985
                I seem to remember the rear connector being in a slightly different location not allowing it to fit.
                • fshead
                  • 2356
                  they are the same..i have done it
                  only have to remove the plastic housing that sits against the main connector..
                  like stated the mpc4503 has bigger/multiple heater lamps..
                  • Pixtech Frameworks
                    • May 2020
                    • 237
                    Thank you
                    Mpc2003/2503/3003/3503 can work for eachother, same lamp 527w, all u need to do is to just change the down case of the fuser unit if it doesn't fit in on eachother.
                    • tullio
                      • Feb 2012
                      • 268
                      Thank you . I solved. works . mpc2003 and mpc3003 are the same.
