Fuser 3002
  • Daniel_B81
    • Jan 2019
    • 43
    Fuser 3002
    Hi, anyone know if the fuser unit of a MP C4502 works in a MP C3002? Or if there is a way to modify it to work on it?
  • Gift
    • Mar 2011
    • 2459
    Re: Fuser 3002
    It works, I think you must swap or modify the bottom cover. Not shure if you need to modify the connector pin assignments.
    Fuser lamp wattage is higher but this does not have any negative effects.
      • 37544
      Re: Fuser 3002
      Looking at the parts catalog, it appears the only differences are the lower cover and the fusing sleeve. Having done many PM rebuilds on the 02s, the leads for the thermistors are attached to the lower cover.
      The higher wattage sleeve might result in warmup service codes as it may actually warmup too fast.
      • MIGUELMARCHENA
        • Feb 2018
        • 195
        Re: Fuser 3002
        When doing this adaptation, it has given me problems like sc540,542
          • 37544
          Re: Fuser 3002
          SC540, fusing motor lock error. Modified fusing unit might be binding and putting too much load on the motor.
          SC542, Warm up error.
