IMC3000. SC672-21
  • GeorgeBest
    • Jul 2009
    • 526
    IMC3000. SC672-21
    Hi
    Customer called, first said that the image was suddenly bad, see picture.
    Then, after restarting the machine it was given a SC672-21 error !
    again, customer restarted the IMC3000, now it tries to start up but after 30sec a "shutdown" screen enters and machine shuts off.
    Today when arriving at customer, only see that the machine starts up and shutt off after 30seconds. No SC672-21
    I guess the control board is defect, because of the SC672-21 in an earlier stage?
    nut sure . . .changed the HDD, no results . .
    Anyone another suggestion before ordering a controll board?
    Thanks in advance
  • Gift
    • Mar 2011
    • 2459
    Re: IMC3000. SC672-21
    Try and start without LAN connection, open doors + firmware SD card (controller slot).
    A bad controller can happen so you can bring a loaner from a parts donator if you have one and this is a contract scenario
    or you like to be shure before ordering a new CTB. Just swap the NVRams.
    • GeorgeBest
      • Jul 2009
      • 526
      Originally posted by GeorgeBest
      Hi
      Thanks in advance
