Ricoh C5100s Not Responging
  • sniper2g8
    • Jan 2013
    • 117
    [Dead] Ricoh C5100s Not Responging
    Customer reported his Ricoh C5100s not responding after booting, when ever he pressed any key it does not respond, what could be the solution to this problem
    • 37533
    Re: Ricoh C5100s Not Responging
    Does the C5100s have any JAVA apps installed? JAVA can take as much as 15 minutes to initialize and start apps. During that time about all you can do is view/print the counter.
    • sniper2g8
      • Jan 2013
      • 117
      Thanks for your responds unfortunately I have no Java applet installed on the machine it just started and the customer have let it on for closed to 2 hour still no respomds
      • bestgik
        • May 2023
        • 2
        I think that you can power cycle the printer: Turn off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power cycling can help resolve temporary issues and restore normal functionality.
        Check the connections: Ensure that all cables connecting the printer to the power source and the computer are securely plugged in. Sometimes i used extract xz file mac, loose connections can cause unresponsiveness.
        Both of these options have worked for me in the past
        • GIUBOSS
          • 1436
          It could be due to the bad hdd.
          • DRichard
            • May 2008
            • 482
            Calling a qualified technician always works for our customers....
            "Enjoy every sandwich."
            -- Warren Zevon
            • bestgik
              • May 2023
              • 2
              You can also reset the printer:
              Locate the reset button on the printer or refer to the user manual for instructions on performing a factory reset. Resetting the printer will restore it to its default settings and can help resolve software-related issues.
              • sandmanmac
                • 3981
                I don't work on the Pro Series machines, but this is just plain BAD ADVICE even on the lower level models.
                So I can only imagine the trouble it would create this model!
