Help to ID a part for a MP 6004ex
  • threehorn
    • Feb 2022
    • 16
    My Ricoh MP C6004ex is flashing that the fuser belt needs replaced.
    Can anyone help ID what part number I need for the intended item to be replaced?
    Thanks much
    • 37488
    Re: Help to ID a part for a MP 6004ex
    D2424041 (na):sleeve:fusing:120v
    • anothertech
      • 1769
      You can usually just reset the PM counter for that item and keep on running.
      • copier tech
        • 8144
        Thanks much
        If you are not a trained tech this is not a part you should be replacing yourself.
