How to change MAC Address Ricoh MP 4054
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    #16
    Re: How to change MAC Address Ricoh MP 4054
    Somebody is smoking something.
    Sorry, no duplicate MAC addresses.
    They may be extremely similar. but NOT the same between any 2 or more devices.
      • 16550
      #17
      Let's just assume for a minute that a company fucked up and issued the same Mac Address 3 times. I don't believe it but lets assume. What are the odds that an individual just happened to end up with those 3 machines? I would say that the odds would be astronomical.
      What are the odds of two devices having the same MAC address?
      zero
      What is the probability of having two identical MAC addresses within one network? The IEEE manages MAC addresses. The hardware identification addresses that the IEEE distributes are unique. That makes the probability of matching MAC addresses zero.
        • 37641
        #18
        For a major nationwide corporation that often purchase an entire day's production from a single manufacturer, I would say extremely possible.
        • rthonpm
          • Aug 2007
          • 2860
          #19
          That would still require a lot of coincidence. All three controllers shipping at the same time for the same build runs, the same PO, and same container to the domestic rep. Unless the serial numbers are also in tight sequence I'd have a hard time believing in that much coincidence. That's like getting lightning to strike you three times on the same day for three years straight at the same location.
          Sent from my Pixel 6 Pro using Tapatalk
          • kevslane
            • Mar 2017
            • 24
            #20
            Fact is he does not have 3 machines with the same MAC address and his problem lies elsewhere on his network and he needs to address that and get over it being a machine problem.
            Sent from my SM-A526B using Tapatalk
              • 16550
              #21
              Okay, lets assume that Ricoh f'd up and issued 3 of the same Mac Addresses. And lets assume that a copier company bought all three machines. And lets assume that the sales dept. sold those 3 machines to the same company. That's a lot of stuff that has to line up. But fine. Lets assume it happened. Again, I'm not buying it, for the record.
              Here's my next question: Why is the OP on here asking how he can change the Mac Address? I'd be on the phone with Ricoh raising hell. No?
                • 37641
                #22
                My guess is that he obtained some used machines that had previously been on @remote with another dealer. Either that or what he is really wanting to do is change the meter.
                • kevslane
                  • Mar 2017
                  • 24
                  #23
                  Hi Slimbob, @remote and meter readings have nothing to do with MAC addresses.
                  • rthonpm
                    • Aug 2007
                    • 2860
                    #24
                    The most logical explanation, if the description we've been given is accurate, is that one machine is set to DHCP without a reservation and he's seeing some old entries for the same MAC address floating around with different IPs.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      #25
                        • 37641
                        #26
                        Hostname can be a life saver when you have a small business that makes it a habit of frequently changing their ISP with no router between the ISP's modem and their LAN. More often then not the ISP installer leaves the modem set for whatever the factory DHCP and LAN subnet are. Very often the third octet can be different from the previous modem.
                        • luca72
                          • Oct 2017
                          • 1792
                          #27
                          I remember the early days of cable internet I had to purchase a cable modem from someplace like Best Buys and run a setup disk from the ISP. The setup disk obtained an IP address for your computer, created your account with ISP and recorded your computer's MAC either on your modem or with the ISP account. That one computer became the only thing that could connect to the internet through that cable modem. Later when I went to wireless, the first Linksys router with WiFi had one of its setup steps being cloning the MAC of your computer. In fact even the Cisco/Linksys E2500 that I am currently using has "MAC Address Clone" as one of the setup tabs. That is the only way I know of where 2 devices can appear to have the same MAC.
                          Now I have seen where the master browser has reported matching computer serial numbers when the serial numbers were too long and the master browser truncated them so the 5 computers purchased from the same vendor at the same time appeared to have the same number. I have also seen IP address conflicts on MFPs. I wonder if that is the actual overlap the original poster has?
                          I did some research out of curiosity, and actually it could be, as you say, a question of the router, in fact on some there is the "clone mac address" function ... so I would check the configuration in the router more than on the machine
                          "I'll be back"
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            #28
                            Look back at the first page.
                            It's a screen shot of the WIM in one of the machines, showing the MAC address.
                            That view does not come from the router, at least AFAIK. It's hard coded into the network card of the MFP.
                            BTW...There is constant confusion (and one of my pet peeves) on CTN with "MAC" being short for "Macintosh". They are NOT the same thing.
                            "Mac" = "Macintosh"
                            "MAC" = "Media Access Control"
                            • rthonpm
                              • Aug 2007
                              • 2860
                              #29
                              "Mac" = "Macintosh"
                              You're not the only one with that pet peeve!!!
                              • luca72
                                • Oct 2017
                                • 1792
                                #30
                                "Mac" = "Macintosh"
                                yes, I had seen it, (couldn't even wear it).
                                ..my boss thinks that the machine's hostname has been changed several times, and the previous traces are still stored in the router, but obviously with the same mac-address, a bit, like when for example you see on your google account some devices that have been connected to the network, even if they are no longer present.
                                "I'll be back"
