Ricoh MPC5502a SC720-00
  • jonyhdtv
    • Jun 2023
    • 2
    I have an MPC5502a giving the codes noted SC720-00 and now is SC720-75. Any ideas or suggestions what i must to do will be greatly appreciated.Thanks all,
    Jack
  • GIUBOSS
    • 1436
    Re: Ricoh MPC5502a SC720-00
    Originally posted by jonyhdtv
    I have an MPC5502a giving the codes noted SC720-00. Any ideas or suggestions what i must to do will be greatly appreciated.Thanks all,
    Jack
    Clean the steel axis in which the stapler runs with a cotton cloth and degreaser, even for kitchen use, then lubricate with synthetic or silicone oil
    • jonyhdtv
      • Jun 2023
      • 2
      Can you point me to which steel axis you are referring to?
      • GIUBOSS
        • 1436
        If you have the booklet the whole staples part should come out just pulling the whole section out and then you will notice the steel axle
          • 37533
          First of all, I do not see a listing in the service manual for SC720-00. SC720-75 is Stacking sponge roller motor Occurs during the operation of the stacking sponge roller motor. This could be the motor for the exit tray sponge rollers or the one that helps stack the paper on the main staple tray.
