rICOH IMC 530FB SC 990-00 ERROR CODE
  • tekkie
    • Mar 2011
    • 114
    [Error Code] rICOH IMC 530FB SC 990-00 ERROR CODE
    Hi Guys
    I have an error code sc 990-00 on a Ricoh imc 530fb machine
    I powered it on and off and its recovered and is working fine
    The manual says its a marking error and lists 4 possible fixes
    1.Power on and off
    2.Upgrade firmware
    3.Replace PCB 2
    4.Replace PCB
    This customer has had a couple of issues on this mc and its fairly new I normally would have been happy that it has recovered and its working but I am just asking to see if anyone else has had this issue on this model
    The firmware update from the screen comes back and says its the latest version which it is
    So I am hoping it was just a one off random error code but just asking to see if any one has any ideas
    Cheers
    • 37623
    Re: rICOH IMC 530FB SC 990-00 ERROR CODE
    Do you have a Ricoh approved power protection installed?
    • luca72
      • Oct 2017
      • 1792
      Originally posted by tekkie
      Hi Guys
      1.Power on and off
      2.Upgrade firmware
      3.Replace PCB 2
      4.Replace PCB
      Cheers
      I don't have that model around, but for such a problem I would try to do this:
      1 - save machine data on sd-card "sp-5-824" and address book via wim, or sp-5-846-051 (generaly)
      2 - hdd format or replace (depending)
      3 - reset sp 801 (all)
      4 - reload data from sd "sp-5-825"
      5 - firmware update (I see that it has a nice full-bodied package), and I try
      p.s. i checked any txt files to see if there was anything about sc990 inside the package, but they didn't put any
      "I'll be back"
      • tekkie
        • Mar 2011
        • 114
        thanks for your advice I will give it a go
