ricoh 7001
  • Gab
    • Aug 2015
    • 656
    ricoh 7001
    Paper jam at DF. Original paper exits about 2cm from the exit of DF and stops . The same when making 2-sided copies.
    I think it is the sensor just after the Df belt ( pert number AW01 0117, paper feed sensor) . Am i right?
  • GIUBOSS
    • 1382
    Re: ricoh 7001
    Have you already cleaned everything there? You could swap the sensor with another one to be sure....
      • 36833
      Re: ricoh 7001
      How about the Jam code, J???. That will tell us a lot more than where the lead edge of the paper ends up at.
      • MIKON
        • Jul 2015
        • 184
        Re: ricoh 7001
        Be sure to clean the black pads on the other side of the sensors.......
        • anothertech
          • 1756
          Re: ricoh 7001
          Yep, it should be done every service call.
