IMC 4500 Fusing issues
  • Gift
    • Mar 2011
    • 2459
    #31
    Re: IMC 4500 Fusing issues
    Originally posted by Exodia-P4
    Hello, the office temperature is ok... no humidity... it will be weird that appear on several copiers not at the same place...
    Yeah that's true so maybe it's a toner issue after all, this can also happen with original ricoh prodicts every now and then. You can try and use toner from a different batch and run at least ~200 full bleed pages to cycle old the old toner.
    • Ricoh-ono
      • 338
      #32
      Originally posted by Gift
      You can try and bump all standby-related temps for the upper/lower fuser roller (1-107-001 onwards).
      If you bump the target temps while using plain paper just bump ALL "plain" related SPs.
      Also make shure the toner density is not too high.
      In addition to the temperature adjustments, you may also want to increase the fuser rotation times.
      Do what you can, with what you have, where you are. ~Theodore Roosevelt
      • Zeldaman
        • Mar 2011
        • 946
        #33
        • Exodia-P4
          • Jan 2023
          • 134
          #34
          Hello, what the number of the smc line that I must look?
          • Exodia-P4
            • Jan 2023
            • 134
            #35
            How I can Do that? The best will increase the fuser rotation time before print I think
              • 37490
              #36
              Originally posted by exodia-p4
              hello, what the number of the smc line that i must look?
              k 7-931
              m 7-932
              c 7-933
              y 7-934
              • Exodia-P4
                • Jan 2023
                • 134
                #37
                k 7-931
                m 7-932
                c 7-933
                y 7-934
                Thanks, do you know how I Can increase the fuser rotation time before print ? I search in parameters and I dont find anything...
                • Exodia-P4
                  • Jan 2023
                  • 134
                  #38
                  Nobody have any ideas ?
                  • Exodia-P4
                    • Jan 2023
                    • 134
                    #39
                    The problem occurs just when the customer print on the internal receptacle BN3130 ??
