MP2852 light copies
  • ponto700
    • 144
    MP2852 light copies
    Hi,
    i have one mp2852 that i have done full PM and machine was working ok but after making some copies they are coming out lights. I already change the PCU and i have the same problem. i have put a new pcu also and they are coming ok then start making the same. i clean the toner hopper also, im using original toner. when i force toner supply the copies are coming ok but again same problem.
    any other ideia what can cause this?
    thanks
  • Dickie
    • Nov 2011
    • 190
    Re: MP2852 light copies
    Have seen a few of these problems, it appears to be a lack of developer material in the new units. If you top it up slightly and reset the developer they appear to run O.K
    • ponto700
      • 144
      same problem with 2 diferent units!
      • KeviM
        • Oct 2019
        • 324
        Originally posted by ponto700
        Hi,
        thanks
        So if I read this correctly you changed the PCU twice and in both cases the copies start of clear but after a bit the blacks start fading. Also you did a complete PM
        Try this
        1) Have you fully serviced your laser unit?
        2) have you fully serviced and cleaned your optics including the white reference strip?
        3) what is your Vsg, Vsp, Vt and Vts reading? These are important for maintaining good print quality.
        4) is your Drum and developer brand new? If not replace with brand new original
        Give some more information after you try these
        All the best friend
        • Dickie
          • Nov 2011
          • 190
          Have you split the unit and looked at the dev roller ?
          We are getting this with the new style units and have to just add a small amount of developer to them all !!
          • Marky2022
            • Jan 2022
            • 5
            If the mag roller is ribbed, it's probably coated? I take scotch bright and clean the mag roller and the run the DV initialization again. When it's coated it looses it's brush.
            I hope this helps !
              • 37533
              2 areas to check. Dirty shield glass and dirty optics
              • luca72
                • Oct 2017
                • 1784
                Hi,
                thanks
                its happen to me, one time was the toner revolver motor that loose force, one time was the revolver that all ramshackled, i suggest you in case of revolver on that specific model replacement, that buy it new, it's cheap, and it's a part that the customer abuses a lot (LOL), it's better to put it back complete
                "I'll be back"
                • Gift
                  • Mar 2011
                  • 2459
                  If the triangle on the counter page looks like a proper black I'd focus on the scanner.
                  Besides dirty optics a bent frame can cause quality issues.
                  Finally you might be able and cheat yourself another default setting for the copy window to improve the density.
                  • Marky2022
                    • Jan 2022
                    • 5
                    Question: Was this an issue before you did the PM ?
                    • copyaction
                      • Oct 2007
                      • 991
                      Did you use a type 1027 pcu as a replacement?
                      • ponto700
                        • 144
                        problem solved.. toner motor was not rotating properly.
                        After change the motor, clean all toner hooper unit again the machine start to make nice copies and printings.
                        thanks to all.
                        • luca72
                          • Oct 2017
                          • 1784
                          I had suggested the toner motor, thanks for giving the feedback
                          "I'll be back"
