Ricoh spc252sf
  • neergish
    • 177
    Ricoh spc252sf
    Have a customer who has changed the default copy settings on a little SPC252sf to do double sided and I have no idea how to change them back copy single sided. I Couldnt find anything obvious in the WIM or in the settings, although I may have been distracted by her 2 cute dachshunds. Any idea?
    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
  • GIUBOSS
    • 1435
    Re: Ricoh spc252sf
    SP C250SF/C252SF download page
    page 112
    login as admin and delete the function added as default in copy mode
    • dalewb74
      • Feb 2018
      • 1153
      Re: Ricoh spc252sf
      i would do it the easy way. select the single sided copy feature. and then select the icon to set that feature as the default.
      • DRichard
        • May 2008
        • 482
        Re: Ricoh spc252sf
        "Dachshunds" (that's a new name for them...)
        "Enjoy every sandwich."
        -- Warren Zevon
