Ricoh IMC3500 - SC144 - SBU Comm error
  • Batman1976
    • Jun 2016
    • 91
    [Error Code] Ricoh IMC3500 - SC144 - SBU Comm error
    Hey Chaps,
    Have an IMC3500 with Sc144 on display, Reseated scanner ribbon cables but no joy. Manual points towards BICU or Scanner carriage assembly replacement. Before I start ordering expensive bits has any one ever seen it before and has a fix?
    Cheers
    Batman1976
  • GIUBOSS
    • 1431
    Re: Ricoh IMC3500 - SC144 - SBU Comm error
    Is there any movement in the scanner before or while reporting the code? One test I would do is unplug the ADF from the box.
    Try moving the lamphead by hand and check for obstructions, if too hard it could be the motor
    1. Reconnect the following connectors: • Scanner carriage - BICU harness (FFC)
    2. Replace the scanner carriage.
    3. Replace the BICU (PCB10).
    4. Replace the following harnesses: • Scanner carriage - BICU harness (FFC)
    • Batman1976
      • Jun 2016
      • 91
      No movement of scanner at power on, no lamp on either. Scanner carriage moves freely by hand, no obstructions. ADF disconnected gives same error.
      • GIUBOSS
        • 1431
        Did you reset it to sp mode? Also check the sc in the history.
        Check the white reference seal on the back of the platen exposure glass
        • luca72
          • Oct 2017
          • 1774
          Originally posted by Batman1976
          Hey Chaps,
          Cheers
          Batman1976
          the machine cannot comunicate with carriage assy, missing comunication, try to replace the ribbon cable first, should be the cheapest attempt
          "I'll be back"
          • TonerMunkeh
            Professional Moron
            • 3865
            Has anyone been in the back of it and swung the controller box out? Just copped for one where someone didn't disconnect the ribbon cable while doing so and mullered it, new cable fixed the problem.
            Hit it.
            • Batman1976
              • Jun 2016
              • 91
              Quick update guys....
              this turned out to be the carriage unit. Replaced complete unit and warranty part.
              Batman
              • copyboy99
                • Jan 2020
                • 23
                recently there are lots of calls regarding scanner carriage (led) unit in b/w IM 5000 series, Color IM C4500 and new IM C4510 series as well..
