Until now from 25 units only one is affected by this problem.
Everything started after the firmware upgrade that fixed SP2801 "failed".
All STB applied on this unit.
Checking 1902 it was showing 36% web used (1 month after initial install in the field) and physically the web was 100% depleted.
Re uploaded the latest firmware available and replaced the web and yes after replacement I cleared SP 7806-008 & SP 7804-005 + 1902 . After 4 weeks same problem.
The only way to reduce this symptom was to slow down the web rotation. Submitted SMC report to tech support for further analysis. No reply yet.
Any other ideas?
Any other ideas?
