MPC6004 with booklet SR3220
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Installed this 6004 with an finisher SR3220
    The customers runs large documents, somtimes more then 300 prints
    The finisher does'nt put the prints correct on its output tray. see the picture . .
    thanks in advance
  • GIUBOSS
    • 1436
    Re: MPC6004 with booklet SR3220
    Check the finisher input conveyor if crooked or bent, I would overhaul the rubber transport rollers, lubricate the paper guides on the steel axes
    • Ricoh-ono
      • 338
      Not sure I understand the question. Are you concerned with the pages stacking crooked or is the tray not lowering far enough to handle the large jobs?
      Do what you can, with what you have, where you are. ~Theodore Roosevelt
      • Gift
        • Mar 2011
        • 2459
        Worn out sponge/reverse rollers or even a a slightly bent output tray frame/holder can lead to issues like this.
        All in all a proper stack alignment is not really good with these finishers in many scenarios any it may vary depending on the paper quality.
        • dalewb74
          • Feb 2018
          • 1157
          not sure how it would line up without it, but the photo doesn't appear to show a jogger. the joggers job is to align the paper into a nice, neat stack. very handy for staple and fold jobs. but as it is, if the text/image on the paper is aligned as it should be. i wouldn't worry about it.
            • 37532
            From the service manual:
            6.15.2 FINISHER JOGGER PROBLEM (FOR BOOKLET FINISHER
            SR3220 (D3B9) / FINISHER SR3210 (D3B8))
            If a paper alignment problem occurs as shown below, do the following procedure to adjust the
            jogger width.
            Cause
            Depending on the type of paper or the manufacturer, the paper may not be the correct size. In
            this case, the paper may not align properly even when the jogger is used.
            Solution
            Adjust the jogger width with SP6-143 (adjustable threshold: -1.5 to +1.5 mm for each paper
            size).
             SP6-143 (Jogger Pos Adj:1K FIN)
             Adjust the jogger width to be slightly narrower (approximately -0.5 mm) than the
            paper width.
