ricoh mpc5503 - problem in color printing
  • tullio
    • Feb 2012
    • 268
    problem in color printing, ricoh mpc5503, with the ricoh mp c2050 ok the print is darker. the mpc 2050 is normal. the mpc5503 is new, it has 39,000 prints made. update done, same problem, new original toners, calibration print is perfect, on the mpc5503 - only from the pc.
    problem. WhatsApp Image 2023-07-27 at 17.46.10.jpg .WhatsApp Image 2023-07-27 at 17.43.35.jpgWhatsApp Image 2023-07-27 at 17.43.48.jpgWhatsApp Image 2023-07-27 at 17.46.27.jpg
    the print is darker. the mpc 2050 is normal. the mpc5503 is new, it has 39,000 prints made. update done, same problem, new original toners, same problem.
  • mikadonovan
    • May 2008
    • 2931
    Re: ricoh mpc5503 - problem in color printing
    Clean the ID sensors and perform color calibration again.
    NEVER ASSUME ANYTHING
      • 37489
      What gives with the crappy "what'sapp" images? You had a full page full color scanner right there in front of you. And are those actually prints from a computer or are they copies of a newspaper, magazine or book?
      • tullio
        • Feb 2012
        • 268
        computer(pc)
        • dalewb74
          • Feb 2018
          • 1153
          what are the print drivers set to? what is the resolution on the copier and the file type set to on the copier?
          • tullio
            • Feb 2012
            • 268
            600x600 . File is pdf.
              • 37489
              Production of the MP C5503 was discontinued when the MP CXX04 line was released. That was 7 years ago. So the MP C5503 is not new. If it does only have 39,000 on it then it has been highly under utilized. The MP C5503 was designed to deliver an average monthly volume of 12,000. 39,000 would be just over 3 months of average usage. That being the case the PCDUs have all died of old age. If you want to optimize image quality, replace all 4 PCDU and do a full PM on the rest of the machine. Oh and do not use anything that is not Genuine Ricoh.
              That takes care of the engine. Now as for the print driver. Do not use any type of Driver for Universal Print or Microsoft V4 driver. A quick test is to print to the C5503 with the C2050 driver. That rules out any difference caused by the driver.
              • Gift
                • Mar 2011
                • 2459
                All images look like crap to me so let's start the funny guesswork: With the proper PCL6 driver you can adjust everything to your liking in advanced settings if the internal test page from printer SP does not show any errors after calibration.
