Unable to add IMC2500 to Ricoh Connect app on iPhone
  • copyaction
    • Oct 2007
    • 991
    • 8144
    Re: Unable to add IMC2500 to Ricoh Connect app on iPhone
    Which phone are you using?
    Sometimes you need to add the IP of the printer manually rather than search.
    Also updating the firmware can help.
    • copyaction
      • Oct 2007
      • 991
      • sandmanmac
        • 3981
        Try F/W Update tool
          • 8144
          We can supply you with the firmware should you want to try that.
          Does AirPrint work ?
          Also turn on IPV6 on the copier that may also help.
          • copyaction
            • Oct 2007
            • 991
            Just tried IPV6, same issue
            Also on AirPrint, no airprint printers found
            How can I go about getting the firmware?
            • copyaction
              • Oct 2007
              • 991
              Originally posted by sandmanmac
              Try F/W Update tool
                • 8144
                Yes that tool is a little unreliable.
                Check you have AirPrint & Bonjour enabled (you can check this via the WIM / webpage)
                Drop us an email from either link below we can supply you with the firmware.
                • copyaction
                  • Oct 2007
                  • 991
                    • 37489
                    Did you cycle power after enabling Bonjour?
                    • copyaction
                      • Oct 2007
                      • 991
                      I did not. I will try that now, thanks for the tip.
