Plockmatic pbm350 fold rollers issue
  • Amor1210
    • Aug 2023
    • 2
    I have a client who just received this plockmatic and the fold rollers are leaving marks. They are the first set of fold roller that aren't smooth and those grooves are marking the sheets lead to trail. This happens on just a single sheet of card stock. I have tone of plckmatics out there and this is a first. Don't recall ever having to adjust these rollers for any gap adjustment in the field. Anyone ever have this issue?
    • 37514
    Re: Plockmatic pbm350 fold rollers issue
    It sounds to me like the rollers might be contaminated with toner or something. To clean them you will need to use something with grit. Scrubs hand cleaner cloths or water-less hand cleaner to lift the contamination out of the surface.
    • Amor1210
      • Aug 2023
      • 2
      Brand new unit. Hasn’t even had time to get dirty with toner. Should have probably stated that in original post.
