Ricoh C4504ex SC-672-00
  • peterxu256
    • Jul 2014
    • 110
    Re: Ricoh C4504ex SC-672-00
    Originally posted by luca72
    you could write a book about the sc672, or make some cool t-shirts, however, I recommend you follow the troubleshooting block diagram for the sc672 which you can find attached numerous times here on the forum.
    it essentially involves following the flashing of the LEDs on the controller, the status of which gives an indication of what the CPU sees.
    it could also be resolved simply by unplugging and reattaching the controller, or updating the firmware, or displaying a USB cable... or even as happened to me some time ago, after having washed the controller board with alcohol and a brush, the problem disappeared, and is no longer got back
    HOW ABOUT ASK chatGPT4 TO WRITE A BOOK ABOUT THE SC672? IS IT POSSIBLE TO DO THAT? THINKING OF OUR PRINTER INDUSTRY MERGED INTO OpenAI TECHNOLOGY
    • DeepRepair
      • Nov 2023
      • 22
      Possible things that cause this code are controller nvram, power supply failure, drum short circuit
        • 8164
        Here is a useful troubleshooting guide on the SC 672 error.
        Troubleshooting - SC672-00 to 13.pdf
        • UNICORNico
          • May 2018
          • 308
          #19
          Surely, it will be a silly question. Where is the reference code of the USB communication cable between 'CTL' and the 'Operations Panel'?
          I can't find it anywhere.
          "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
            • 37515
            #20
            Try the Point to Point diagram.
            • luca72
              • Oct 2017
              • 1781
              #21
              s Panel'? I can't find it anywhere.
              as slimslob says, you can also use part finder, after open the file, at the top there are buttons where you can choose the harness section
              "I'll be back"
                • 8164
                #22
                As Slim said point to point diagram is good for harness part numbers.
                New part number is D2411482
