Stray toner on envelopes
  • alcopost
    • Aug 2023
    • 1
    I'm getting stray specs on the non-imaging part of envelopes. It's random, like the toner is spraying and sticking to a random part of the paper. I have run letter-size documents with much more coverage and not seen this problem at all.
    Ricoh IM C6000 with less than <100,000 clicks. Toner is not low. OEM. Drums, fuser rollers, and transfer belt have been cleaned. Any ideas what the issue could be?
    If it might be a leak or problem with a drum, how can I determine which drum is the problem? It doesn't seem color dependent. Please see attachments.
  • UNICORNico
    • May 2018
    • 308
    Re: Stray toner on envelopes
    Please take pictures at higher resolution or use the device's scanner as far as possible. In the photographs provided (at least I), I do not observe the problem described. Do I check the cleaning unit of the ITB?
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • jermyth
      Riso dude
      • Mar 2011
      • 441
      What media mode are they running? They should be using thick 2 or 3, not envelope mode, it's not enough heat and too fast.
      • dalewb74
        • Feb 2018
        • 1157
        what are the bypass paper settings set to?
        • Gift
          • Mar 2011
          • 2459
          Probably just some dirt somewhere in the paper path - thick mediums do tend to touch and pull dirt along before the issue appear on normal paper. A dirty fuser entrance area is a common cause, also inspect the area between registration and fuser entrance. All in all I wouldn't recommend this machine for envelopes except this is only needed every now and then.
          While cleaning the transfer belt make shure you clean the inner side of the frame part I've marked red here:
          And check the area where the MUSIC sensors are sitting.
