Fax to Email
  • Methedor
    • Nov 2016
    • 69
    Fax to Email
    Hello, everyone. I've been running into an issue with a client request. The client IT has attempted to configure what they call Fax to Email on an IM 350, but has ran into issues. They have experience setting up the Bizhubs for this and was configuring Internet-fax. My research along with my tech support contacts have been finding ways to receive fax and forward to email or various SMTP reception settings while the client is wanting transmission. The flow as describe should be [Faxnumber]@fax.xxx.com from the unit to their exchange sever and from their to a local fax server.
    I have looked into and provided the fax area of the user manual, as mentioned above, sent information that appeared to fit scheme. Reportedly attempts have at least an E1 error. The Email in the fax App also has not solved the issue. I am wondering if I and my support contacts have just missed something small or are focused on an erroneous aspect of this. I do hope this makes a connection with someone here even if it is just a correction for my focus. Thank you, brain trust, for your time and effort.
  • copier tech
    • 8142
    Re: Fax to Email
    First add the email address to the address book you want to incoming faxes forwarded to.
    Then go to fax reception setting & turn on forwarding etc.
    Here's a handy little video.
    How to Setup Fax Forwarding on Your Ricoh/Savin IM Series - YouTube
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
        • 37480
        Re: Fax to Email
        There's an internet service that has been available for years called eFax. To send a fax just email to faxnumber]@efaxsend.com. You can also send from your computer or mobile device using their app. You also get a phone number that others can send faxes to. You receive them as an email attachment. They also have HIPPA compliant plans.
        When I was in Iraq in 2005 couple of other senior NCOs and I had accounts with them. Came in quite handy when soldiers in our unit needed documents from their home unit. We would give the soldier one of our eFax numbers and tell them to have their unit fax the documents. None of our soldiers ever missed a cut off date for submitting a promotion packet.
        There are probably other such services available.
        • Methedor
          • Nov 2016
          • 69
          Re: Fax to Email
          KenB Slimslob: "There's an internet service that has been available for years called eFax. To send a fax just email to faxnumber]@efaxsend.com."
          If i am understanding you correctly, provided that this is a similar service, it would be Scan to Email using the faxnumber and not Email under the Fax App (internet fax, IIRC)?
          Thank you for reading and responding.
          • dalewb74
            • Feb 2018
            • 1150
            Re: Fax to Email
            hey slim. was just reading your post. looks like you were rolling around baghdad the same time i was. though i left in march. so maybe not the same time. but we ran some of the same roads i am sure. SCOUTS OUT FRONT!!
              • 37480
              Re: Fax to Email
              After training at Fort Lewis, we departed McChord Air Force Base early morning December 22, 2004 and landed in Kuwait Christmas Day. We convoyed Ballad/Anaconda in January 2005. Coming back we went wheels up just before midnight November 30th.
              • dalewb74
                • Feb 2018
                • 1150
                Re: Fax to Email
                yeah we convoyed from kuwait, like everyone else. i don't believe i went to anaconda, if so was a brief in and out. i was around taji and a bit south.
                • dalewb74
                  • Feb 2018
                  • 1150
                  Re: Fax to Email
                  sorry i will refrain from taking over the post....
                    • 37480
                    Re: Fax to Email
                    I was with a transportation unit. Taji was a frequent destination for our convoys.
