Ricoh aficio sp 5210sr sc202 error code, need to find a repair video or intructions
  • IrishDon5
    • Apr 2022
    • 2
    [Error Code] Ricoh aficio sp 5210sr sc202 error code, need to find a repair video or intructions
    Hello,
    Iam currently working on a Ricoh Aficio sp 5210sr, which is giving a sc202 error code which means that the polygon mirror motor needs to be replaced. Finding the error codes meaning wasn't hard to do at all but finding a video of how to fix this particular video or instructions online is next to impossible. Can someone please help me out with this, as a video for my particular model and or instruction would be perfect as I have the part in hand to fix ASAP. Thank you for your time.
    Regards,
    IrishDon5
  • dalewb74
    • Feb 2018
    • 1153
    Re: Ricoh aficio sp 5210sr sc202 error code, need to find a repair video or intructio
    i very highly recommend you find a certified tech....
      • 37490
      YouTube repair videos are for idiots, service manuals are for intelligent people. An intelligent person would put a request in the Service Manual Requests forum https://www.copytechnet.com/forums/s...nual-requests/
      • luca72
        • Oct 2017
        • 1778
        Originally posted by IrishDon5
        Hello,
        Regards,
        IrishDon5
        before disassembling, I advise you one thing, I checked in the calls of that model, since we have different ones, and I have two error codes of those, one I replaced the polygon laser motor, and the other an actuator broke plastic that activates a switch to enable the laser, which you can find inside the cartridge compartment door, you open it, look on the door, and there must be a plastic protuberance that when you close it slides into the machine to press a microswitch, it usually breaks because the customer, when removing or placing the cartridge which is large and heavy, makes it slide over it, and since it is quite long and thin it breaks
        Ricoh has foreseen all this, in fact in order not to replace the entire door, the part can be replaced because it is fixed with a screw
        "I'll be back"
