MPC4503 noise
  • GeorgeBest
    • Jul 2009
    • 526
    MPC4503 noise
    Hi,
    Custommer called for noise when loading paper in cassette 2
    lift motor is working, but at the end it gives a noise as if gears not turning
    Paper feed is allright, also no jams when using cassette 2
    lift motor?
    Thanks in advance
  • Popolopo
    • May 2023
    • 134
    Re: MPC4503 noise
    Originally posted by GeorgeBest
    Hi,
    lift motor?
    Thanks in advance
    Yup. Tray lift motor. The gear on the motor inside crack causing noise.
