Ricoh MP C2004 registration issue?
  • copiertec
    • Jan 2016
    • 2211
    #16
    Re: Ricoh MP C2004 registration issue?
    Well I went back and first thing I did was remove the transfer belt cleaning unit and vacuumed it out, then I cleaned the ID sensors and it is working good no more jamming and all the colors are back in alignment. I did inform the customer that they will be needing a black pcu soon and they did break a paper guide that I need to order and replace. Thanks for the help.
    • copiertec
      • Jan 2016
      • 2211
      #17
      Originally posted by luca72
      mamma mia! what a mess!...in my opinion there is something wrong there!...is the PM counter real?
      however the ID sensors are the ones in the photo, you have to clean all 3 slides, then try to do this in sequence
      sp 2-111-004 forced line adjustment
      sp 2-194-007 check registration 0=ok 1=ng
      sp 2-194-(010 to 013) check music result for each sensor
      0=not executed
      1=ok (they must all be 1!)
      2=unable to execute
      3=number of line less than the model
      4=out of range
      P.S
      Personally, they seem like more PCDUs that need replacing
      [ATTACH=CONFIG]60091[/ATTACH]
      Thank you, luca72.
