Ricoh MP C2004 registration issue?
  • copiertec
    • Jan 2016
    • 2211
    A Ricoh MP C2004 ex with jamming and registration issues upon arrival. Cleaned all rollers in paper path, especially registration. Happens out of any tray copier only has 98,730 total black and 30,102 on total color. Insprected all drum units, developer units, transfer belt all look good, Firmware ver 1.08. Ricoh MP C2004ex.pdf
  • copier tech
    • 8221
    Re: Ricoh MP C2004 registration issue?
    A Ricoh MP C2004 ex with jamming and registration issues upon arrival. Cleaned all rollers in paper path, especially registration. Happens out of any tray copier only has 98,730 total black and 30,102 on total color. Insprected all drum units, developer units, transfer belt all look good, Firmware ver 1.08. [ATTACH]60077[/ATTACH]
    From looking at your print sample I would say the issue is with the transfer belt.
    Take the unit out, remove & clean the cleaning unit & check for belt damage or a label stuck on the belt etc.
    • copiertec
      • Jan 2016
      • 2211
      I did remove the transfer belt and it looked okay, but I did not remove the cleaning unit.
        • 37628
        From looking at your sample I would say that you have multiple problems. The color lines are most likely caused by a dirty cleaning blade in the ITB cleaning unit. If you don't fix that soon it is going to damage the belt if it hasn't already. You may need to replace or rebuild the cleaning unit as the blade might already be damaged.
        Next you have a dirty ID sensor assembly, probably caused by the toner left on the ITB by the cleaning unit. There is a distinct possibility that just properly cleaning the entire assembly will pull the registration back in when pro con is ran at power up.
        • copiertec
          • Jan 2016
          • 2211
          Thanks Slim, The paper is running A3 orientation so those lines are from top to bottom and images are being cleaned off by the blade. I am going to remove the cleaning unit and also make sure the ITB is turning properly as well.
            • 37628
            Every time I have seen lines like that it has been either a damaged, nicks, or paper scraps on the blade.
            • anothertech
              • 1771
              The colored lines don't go all the way to the edge of the paper.
                • 37628
                That being the case you have 4 PCU with bad charge rollers.
                • copiertec
                  • Jan 2016
                  • 2211
                  I just looked at the scans, the office crew did not clean the glass here are the revised images. The paper is running A3 though the copier. Sorry about thatTake 2.pdf
                    • 37628
                    I just looked at the scans, the office crew did not clean the glass here are the revised images. The paper is running A3 though the copier. Sorry about that[ATTACH]60085[/ATTACH]
                    If the color squares sheet was initially printed LEF, a dirty ID sensor is still the most likely cause of the color registration problem. Forced line position will fail if the sensor is dirty.
                    • emiliorsg
                      • Jul 2018
                      • 141
                      It seems that you have a bk PCU that is going hard and is causing a color registration failure. Try another PCU.
                      • copiertec
                        • Jan 2016
                        • 2211
                        Where is the ID sensor located? I did vacuum out the copier, maybe I missed it. I found it. It's located above the transfer belt assembly, I will clean this as well.
                        • luca72
                          • Oct 2017
                          • 1792
                          mamma mia! what a mess!...in my opinion there is something wrong there!...is the PM counter real?
                          however the ID sensors are the ones in the photo, you have to clean all 3 slides, then try to do this in sequence
                          sp 2-111-004 forced line adjustment
                          sp 2-194-007 check registration 0=ok 1=ng
                          sp 2-194-(010 to 013) check music result for each sensor
                          0=not executed
                          1=ok (they must all be 1!)
                          2=unable to execute
                          3=number of line less than the model
                          4=out of range
                          P.S
                          Personally, they seem like more PCDUs that need replacing
                          "I'll be back"
                            • 37628
                            Considering that it is a MP C2004, the black PCU is definitely beyond PM count. The color PCU are at 63%, unless they do a lot of 1 & 2 page jobs in which case the distance count might be over 100%.
                            PCU (K) PM 60K
                            PCU (C,M,Y) 48K
                            • copier tech
                              • 8221
                              From this sample it looks like the transfer belt is stalling. Take the unit out & check it turns freely by hand.
                              But as I said previously remove & vacuum out the cleaning unit etc.
