Ricoh Aficio MP C1500SP / B229 firmwares
  • e6i3i
    • May 2020
    • 26
    Hello,
    I'm looking for the latest firmwares for my Ricoh MP C1500SP copier.
    Does anybody have them somewhere ?
    Or the firmware history doc file ?
    Here are my actual versions, for info :
    Fax 05.00.00 B2295522D
    Security Module 1.03 B2295523B
    System/Copy 1.31 B2295521N
    Fax(option) 03.00.00 B2295524B
    SD Scanner p1_1.23 B2295525D
    Network Support 5.13 B2295526F
    Web Support 1.06 B2295527E
    Network DocBox 2.01.7 B2295528D
    SD Printer 1.08 B2295540H
    SD#1 PCL Font 1.00 B7675383
    FCU 04.00.00 B2295571C
    Engine V1.14:03 B2295581F
    I really appreciate any help you can provide.
    Cheers
  • GIUBOSS
    • 1436
    Re: Ricoh Aficio MP C1500SP / B229 firmwares
    Have you encountered any issues that need fixing with the firmware? RFUT ?
    • e6i3i
      • May 2020
      • 26
      Hi,
      I have an issue related to the samba version I need to use to get the "scan to folder" feature working, on a recent Linux (Debian).
      Linked with that I've never checked before if fw were available for this printer, and after a quick check it is not in the "supported" list of RFUT
      I have an issue on this printer with A3 printing : the last 2cm (if fact, the last pass of the printhead !) shift from about 8mm on the paper.
      I face this issue a really little on A4 paper in landscape mode only, but it seems constant on A3 printing
      I do not think it's a firmware issue, but as I'm working on it, and if I can fix the SMB problem and refresh the printer that would be great.
      Cheers
      • luca72
        • Oct 2017
        • 1784
        Originally posted by e6i3i
        Hello,
        Cheers
        this is these i found for you...It may also be necessary to enable the port and/or protocols on the old machine via telnet
        Color Multifunction: Aficio MP C1500/C1500SP/Aficio 615C
        Firmware Download
        Release Date:all1day1week1month3month6month1yearSearch:
        Network Support NIB GEN ( all ) B2295526J Ver.5.21 2010/09/09 3,871 KB Download
        System/Copy System GEN ( all ) B2295521P Ver.1.32 2009/04/18 11,956 KB Download
        SD Printer Printer GEN ( all ) B2295540J Ver.1.09 2009/04/04 3,486 KB Download
        MBU FCU GEN ( all ) B2295571D Ver.05.00.00 2008/10/10 1,276 KB Download
        Engine Engine GEN ( all ) B2295581G Ver.1.15 2008/08/01 845 KB Download
        Web Support WebSystem GEN ( all ) B2295527G Ver.1.08 2008/03/13 2,609 KB Download
        SD Scanner Scanner GEN ( all ) B2295525E Ver.p1_1.24 2008/03/01 807 KB Download
        Security Module DESS GEN ( all ) B2295523B Ver.1.03 2008/03/01 491 KB Download
        Network DocBox NetFile GEN ( all ) B2295528D Ver.2.01.7 2007/04/05 1,168 KB Download
        Fax(option) RFax GEN ( all ) B2295524B Ver.03.00.00 2007/02/21 629 KB Download
        Fax Fax GEN ( all ) B2295522D Ver.05.00.00 2007/02/20 1,381 KB Download
        Option PS3 PS GEN ( all ) B8505601A Ver.1.01 2006/06/30 2,048 KB Download
        Option PctBrdg PictBridge GEN ( all ) B8245600A Ver.1.04 2006/05/16 561 KB Downloa
        "I'll be back"
        • e6i3i
          • May 2020
          • 26
          Hi,
          I really thank you for this feedback, that's really interesting
          Unfortunately, I do not have octopus account, so I cant DL or read the release notes, but I see some updates regarding Engine, network, etc.
          Is it possible to forward me these updates, trough the forum mp or via any relevant mean ?
          Cheers
            • 37532
            The MP C1500 may be too old to support SMB v2/v3. Does anyone have the most recent version of the list of models that support SMB v2/v3. All I can find was published in 2017. If it is not on the list it is not supported. The oldest models it shows are the MP Cxx03. The processor used in Product Codes begin with B may not support the needed firmware.
            • e6i3i
              • May 2020
              • 26
              Hi,
              Thanks for your feedback, I think you are right regarding SMB v2/3.
              I will check how to mitigate the usage & the feature on the Debian system.
              Regarding the updates of the firmware, even if it was not on the supported list, I"ve done a couple of try & I can confirm that RFUT worked well with this platform !!!
              For those who have difficulties to make RFUT working, you must pay attention to the services enabled on the device : it needs HTTPS, SNMP v1/2, FTP enabled to works well !
              I have also enabled SSDP, but I'm not sure it is used by RFUT (I give it for info).
              I've spent a little time because FTP service was disabled... when something miss on the device, RFUT is saying : "The device is not turned on. Or the device is not specified." that's pretty unclear !!
              In the help of RFUT, I've found this list of need services :
              SNMP 161
              • To add one or more devices.
              • To obtain information for remote firmware update.
              FTP 21
              • To update firmware.
              • To obtain or update (in Pasv mode) firmware information.
              HTTPS 51443
              • To communicate with a device running JavaTM Platform for extended functions or a device where Java VM is available for SD card options.
              • To obtain or update application information.
              HTTPS 443
              • To communicate with a device for which port 51443 is not available for communication, such as a device not running JavaTM Platform for extended functions.
              • To obtain or update firmware information.
              I hope this will help people who are looking to refresh their old devices
              For info regarding my hardware problem on a3 printing : it's still here, but really less, as I was able to print 2 sheets well, on 4 sheets printed... before, it was near 1 sheet well on 10 printed !
              Cheers
              • rthonpm
                • Aug 2007
                • 2859
                If you're scanning to a Debian system, instead of opening up SMB1, just scan to NFS. If Windows clients need to access the same files just share the same directory through Samba.
                NFS has issues of its own, but it's still considerably better than SMB1.
                Sent from my Pixel 6 Pro using Tapatalk
                • luca72
                  • Oct 2017
                  • 1784
                  Hi,
                  Cheers
                  I'll send them to you via pm, inside each one there is the txt file with the version changes
                  "I'll be back"
                  • e6i3i
                    • May 2020
                    • 26
                    Hi luca72,
                    I thank you very much for your help, that's greatly appreciated !
                    Cheers
