Savin 7502 Printing Slow Problem
  • Porhuor
    • Feb 2023
    • 30
    This can prints fast at the first start about 20 pages, then it became slower. I tried to change IP, set low resolution and speed in the printing software from PC, but the issue still cannot resolve.
    Dear all you have any instruction? Please kindly address thank in advanced.
  • UNICORNico
    • May 2018
    • 308
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • luca72
      • Oct 2017
      • 1792
      Re: Savin 7502 Printing Slow Problem
      check in advanced tab on windows driver if use the "IPP port" or "WSD port" if so...change it to ip address of machine...anyway also for driver, the best choice its PCL6
      "I'll be back"
      • Codex
        • May 2008
        • 705
        What kind of files do you print?... Have you checked the Pc?... If its continuing sending the file while the machine is printing..?
        Inviato dal mio SM-S901B utilizzando Tapatalk
        Memento Audere Semper
          • 37628
          It may be doing automatic cleaning and ProCon during print jobs. Check SP 2506.
          • Porhuor
            • Feb 2023
            • 30
            My firmware
            • Porhuor
              • Feb 2023
              • 30
              2.I used the latest driver PLC6
              3.Low resolution to 300dpi
              all still can not solve
              • Porhuor
                • Feb 2023
                • 30
                Dear
                I used Ip address
                • Porhuor
                  • Feb 2023
                  • 30
                  PDF file, I used same PC print to other machine no problem. After sending completed it still slow printing.
                  • Porhuor
                    • Feb 2023
                    • 30
                    SP 2506 it is default ON
                      • 37628
                      Try turning it off or set SP 2506-002 to 100. Also try increasing buffer setting.
                      • GIUBOSS
                        • 1437
                        Are you sure you don't have network connection problems, have you tried a direct connection to the machine?
                        • Porhuor
                          • Feb 2023
                          • 30
                          Sorry for late respond i will try thank you
                          • Porhuor
                            • Feb 2023
                            • 30
                            I think may be no problem, due to other machine work as normal.
                            • rthonpm
                              • Aug 2007
                              • 2860
                              Doesn't mean you don't have a bad cable, bad wall jack, or flaky switch port.
                              Sent from my Pixel 6 Pro using Tapatalk
