MP 2554 printing random pages with Wingdings at the top
  • copyaction
    • Oct 2007
    • 991
  • UNICORNico
    • May 2018
    • 308
    Re: MP 2554 printing random pages with Wingdings at the top
    I would activate user control and a code on each computer. You'll see how the rat jumps xD hahaha
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • rthonpm
      • Aug 2007
      • 2858
      It's probably some kind of security or network scanner that's probing open ports on the network. The MFP gets the query and tries to interpret it as a print job.
      If there's no such device on the network, there may be something malicious that's doing the same thing, though 99% of the time it's a Nessus or similar server doing a security sweep.
      Sent from my Pixel 6 Pro using Tapatalk
        • 37513
        Someone may be trying to hack your network by using port 9100. 9100 is normally a printer port. It is trying to exploit a vulnerability in Windows Mac or both. If you have any vulnerable computers any stored data may already be compromised. The IP Address 75.80.21.237 is a Charter/Spectrum customer in Carlsbad.
        • rthonpm
          • Aug 2007
          • 2858
          The fact that an MFP is accessible from the Internet is even more disturbing...
          • copyaction
            • Oct 2007
            • 991
            Thank you. That may be what we need to look for as the printer is also located in Carlsbad but the network in the office including the printer is 192.168.1.xxx.
            • rthonpm
              • Aug 2007
              • 2858
              Any kind of ISP security appliance on the WAN side?
              • copyaction
                • Oct 2007
                • 991
                  • 37513
                  There is another possibility, since the third line identifies the sending device as a Mac OS X 10.11 it could be someone in their office that doesn't access to the LAN is trying to setup Air Print.
                  • drbing
                    • Dec 2016
                    • 42
                    try with another management program. the same thing happened in my case.
                    Sent from my SM-A707F using Tapatalk
                    • copyaction
                      • Oct 2007
                      • 991
                      These came in this morning. Same ip address but looks like different OS.
                      Any way to block this?
                      • rthonpm
                        • Aug 2007
                        • 2858
                        User agents are trivial to spoof, however it's time to get the client's IT or ISP involved to track down the offending device.
                        • JLSam
                          • Jun 2015
                          • 605
                          I've seen this before with Sharp MFP's.
                          Turned out that it was isolated to one computer, this was an accounting PC. When they print, it prints directly from their application. When saving document and printing directly from the printer driver, it's okay, but when they use online application, it prints this message.
                          I don't know what the solution was.
                          • luca72
                            • Oct 2017
                            • 1781
                            try to stop in wim some unused protocol, like bonjour, air-print, and other, shut-down the wi-fi of the SOP(if you have) just for a pair of day for try
                            "I'll be back"
                            • copyaction
                              • Oct 2007
                              • 991
                              I spoke with the person in accounting today and she mentioned the HP printer in her office does the same thing sometimes. I removed the Ricoh from her computer and we will see if it happens again.
