No black on colour prints and colour test page on ricoh mpc4503
  • Pixtech Frameworks
    • May 2020
    • 238
    Good Day All,
    Has anyone come across sudden black disappearance both on colour prints, colour test page and even counter page, even after swapping PCDU image still remains same. Attached is sample.
    • 37532
    Re: No black on colour prints and colour test page on ricoh mpc4503
    It could be the K transfer roller in the ITB assembly. If the cam that lifts it when the ITB assembly is latched in place fails, you get either no black or very weak black.
    • RicohBoomer
      • May 2022
      • 40
      If you interrupt the job and check the drum physically, can you see traces of the print image on it?
      It is likely what Slim said and something is off with the ITB/Black transfer roller. If all the other colors are fine then it can really only be these two things as everything else should affect all colors.
        • May 2020
        • 238
        Tried switching with another ITB still the same no black.
          • May 2020
          • 238
          Tried interrupting the Printing, no traces of black image on DU or ITB.
          • RicohBoomer
            • May 2022
            • 40
            Does the drum rotate at all? I assume it does because I think it throws an SC code if it doesn't rotate.
            I guess the only other thing I can point to is the power pack that charges each respective transfer roller. If you have another machine to pick from you could try replacing that and see if it changes anything.
            Although only one color breaking and with no SC code to boot is pretty rare.
            • ccchuah
              • Mar 2009
              • 157
              confirm the dv tank are rotating, check the two white gear from the front side of pcdu are turning.
              If not turning check the solenoid at the back that controlling the black dv tank motor.
                • May 2020
                • 238
                Drum rotates even when I initialize TD sensor black it completes. Where's is the powerpack located.
                  • May 2020
                  • 238
                  DV tank is rotating even at TD Initialization sc3030-003 it rotates while cheating on the front door
                  • RicohBoomer
                    • May 2022
                    • 40
                    You have to loosen the controller box and swing it out and then you'll see this red marked PCB.
                    Once you get there you can't really miss it.
                      • May 2020
                      • 238
                      I have swapped part with an old machine part, problem still the same
                      • luca72
                        • Oct 2017
                        • 1784
                        if you try to turn with finger the black developer unit rear gear , the magnetic roller turn?
                        "I'll be back"
                        • Codex
                          • May 2008
                          • 704
                          +1 for BK development unit, some worn out gear, the motor turns normally , but the magnetic roller doesnt turn.
                          Memento Audere Semper
                            • May 2020
                            • 238
                            It turns perfectly.
                              • May 2020
                              • 238
                              I have swapped PCDU still the same no black
