Ricoh MPC4504 Cannot Access Service Mode.
  • Lew_OS
    • Feb 2023
    • 5
    Hi, I've got a bit of a strange one, with a machine that I am looking at.
    If I go to access service mode, it will not appear no matter how many times I insert the code or hold the button, nothing it wont appear. but when I got to access Factory mode it works straight away.
    I've have done firmware updates on the printer, re-formatted the HDD, Factory reset and tried every other service mode code there is. but it will not show.
    Don't suppose anyone ever seen anything similar?
  • Elmo
    • Feb 2010
    • 541
    Re: Ricoh MPC4504 Cannot Access Service Mode.
    Service mode can be locked in Admin settings
    I Used To Live To Fix Things Now i Fix Things To Live
    • Lew_OS
      • Feb 2023
      • 5
      Service mode lock? Thats turned off aswell.
      • Elmo
        • Feb 2010
        • 541
        Have you tried Factory resetting the sop screen in android mode
        • Lew_OS
          • Feb 2023
          • 5
          I have not, and to be honest. That is something I've never had to do before. is it a simple thing to do?
          • Elmo
            • Feb 2010
            • 541
            PM'd you instructions
            • sandmanmac
              • 3981
              Sounds like some service tech "hero" may have changed the SP mode access number.
              You could try using 107107.
              I've heard of several occasions where it has been changed to a version of the old access procedure and this has worked (because the code has to be 6 digits)
              Otherwise, to the best of my knowledge it's a 1-time ONLY change, only and no way to restore it - other than maybe NvRam replacement?
                • 37515
                My understanding is that it can be changed again but only from SP mode and not from factory mode.
                • sandmanmac
                  • 3981
                  Ah Yes.....Now that I think about it, I'm pretty sure you are right about that Tim.
                  • copier tech
                    • 8164
                    Sounds like someone has changed the service mode entry code.
                    If this is the case the only way to reset this is to replace the NVRAM.
                    โ€‹
