Jam Code
  • Ado Mmoloki Moepedi
    • Jan 2022
    • 32
    Jam Code
    Good day, anyone with Experience on with the J050 jam code on a Rich Mono Copier. The paper Jams with a bit of it in the exit unit and most of it in the fusing unit.
  • Saturn
    • Nov 2023
    • 172
    Re: Jam Code
    Which machine are we talking about?
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • Jan 2022
      • 32
      Re: Jam Code
      Ricoh MP2501sp
      • Saturn
        • Nov 2023
        • 172
        Re: Jam Code
        Except for the Baron, I can't find the Jam code J050 in any Ricoh manual. Is the paper damaged at the leading edge? Is the paper size of the tray set correctly?
        • luca72
          • Oct 2017
          • 1792
          Re: Jam Code
          maybe, perhaps the plastic fuser unit guide (the open/close one with the spring on the side) could be deformed by the heat, also clean the paper exit rollers well, set the energy saving to 1-2 minutes max. on that model, set sp 1-996-005 to 90 sec. to increase the running time of the hot air exhaust fan
          "I'll be back"
            • 37628
            Re: Jam Code
            From the service manual "Paper does not reach the registration sensor (from the by-pass tray)." If not using the bypass but are trying to duplex, problem with duplex gate.
