Guys i need a help i have a client with an MPC2800 machine he has overtoner issues but i cant find any developer to replace does anyone tried any other model that the developer may be compatible with the MPC2800?
Ricoh MPC2800 cyan overtoner
Re: Ricoh MPC2800 cyan overtoner
they are all the same, you can also use those from the metis series, (and vice versa) the important thing is the weight... (tested several times in person)"I'll be back"Comment
I have used the old c2500 in some c4501 and without problems. The difference, as Luca says, is between 5 and 15 grams.Comment
Old machine, but I think MP C3300 developer is the same.NEVER ASSUME ANYTHINGComment
Example, using MPC5503 developer, use MPC2800 amount of weight?Comment
you can add the developer of another model, but the quantity must be the same, (more or less) I do it by eye, but I'm trained...lol..however, normally you can find the necessary quantity expressed in grams, in sp 3-420-001 (k), and 002 (cmy) are settings, but you just have to look at it"I'll be back"Comment
