how do you approach no WIM and printer not found with windows 11
i had an odd call where a machine installed 2 years ago and connected to 15 PCs and no issues,would not work on one PC.
I checked machine MPC3504EX and made sure wifi was off and anything odd.
machine is connected via cat5 cable.
I tried to install via windows and machine was not found and adding manually did not work either.
I tried to ping IP address and reply all worked.
I then try logging on via WIM and nothing came up.
I have a 2nd machine just for the accnt and PC found it and printed no issues.
I had to cut my time due to dr appnt but need to revisit..
same antivirus is installed on all working PCs..
ANY THOUGHTS
THANKS
ANY THOUGHTS
THANKS
