Ricoh c3503 Noise
  • Jinn
    • May 2023
    • 120
    Ricoh c3503 Noise
    Hi,
    Ricoh C3503 Development solenoid is giving noise. Solenoid replaced already.In I/O mode its orking fine. When checking Transfer Drum motor it gives noise.Becase slenid plunger is not down and it engages with the gear. Any suggestions?
  • luca72
    • Oct 2017
    • 1762
    Re: Ricoh c3503 Noise
    Originally posted by Jinn
    Hi,
    can be noise motor under load, but i should hear it
    "I'll be back"
    • ccchuah
      • Mar 2009
      • 155
      The white locking plunger already wear off, try filing the edge of locking back to 90 degree in order for it to play when the solenoid is activated and release.
        • 37445
        Can you describe the noise?
