Convert "MPC2004" to "MP C2004ex" by changing the CTL. Is it possible?
  • UNICORNico
    • May 2018
    • 308
    The device is "MP C2004" (without PS3) which has been installed for more than 7 years, was installed new, and was replaced with a new "IM C2010".
    Obviously we want to recycle it to install it in a client with a rental service, since the client who had it did not require much work on the device, and it has less than 80K.
    The question is that acquiring the new CTL is beyond the current budget, and even more so at the time we are in, and we have a used machine distributor that can provide us with the "Controller Board" of an "MP C2004ex".
    Does anyone know if this substitution is possible?
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • 37566
    Re: Convert "MPC2004" to "MP C2004ex" by changing the CTL. Is it possible?
    Can that "used machine distributor" provide you with a complete "parts machine?" The Controller might not be the only board you will need. If you have the EX parts catalog, check it to see.
    • UNICORNico
      • May 2018
      • 308
      I have located the parts, but I'm curious if anyone tries to change the CTL alone. Obviously it will be necessary to replace BICU as well.
      But I'm curious to know if anyone did the experiment of changing only the CTL of the MPC2004ex, or some of the 04 series.
      • DRichard
        • May 2008
        • 482
        Quick and simple answer is "No".
        ...although, with enough time, expertise and MONEY, anything is possible.
        "Enjoy every sandwich."
        -- Warren Zevon
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          I have once mistakenly fitted an EX controller to a standard machine it DOES throw a board mismatch error.
          • Gift
            • Mar 2011
            • 2459
            Yeah I also think the chance is close to zero. Better get a PS option if you need PS for the new customer - it's not really pricey if you get your hands on a properly uninstalled M19 card.
            • copier tech
              • 8195
              This is possible, but you would need to swap multiple parts & boards that have a different part numbers, if you have 2 devices side by side & the time I don't see why not but for very little gain.
              โ€‹
              • UNICORNico
                • May 2018
                • 308
                It's not for that reason.
                The CTL shows a 'SC 672-00' and honestly for the cost of a new CTL, we have managed the sale of a brand new 'IM C2010' machine.
                Sorry if I didn't express myself correctly.
                Despite this, we are trying to "recycle" the 'MP C2004' to be able to amortize it a little more, as mentioned above, the client used it very little for the 7 years of "use", although they had it more as a scanner, instead of printer.
                • luca72
                  • Oct 2017
                  • 1791
                  in my opinion it can work, but you also have to load the other "ex" firmware for the other cards, and after make the seriar number sp procedure as always, it's worth a try.
                  p.s. Two years ago I put the operating panel of an mp4002 on an mpc 2003 which was broken , obviously I loaded the panel firmware for the mpc2003
                  in my opinion they always basically use the same controller on multiple models, with different software and some differences in CPU and RAM, and in the position of the USB ports or other
                  worth a try....let us know!
                  "I'll be back"
                  • Gift
                    • Mar 2011
                    • 2459
                    Ah I understand - guess the only way to fix this is finding a compatible donator or a 2nd hand deal.
                    • UNICORNico
                      • May 2018
                      • 308
                      My intention is to experiment.
                      Regarding the situation, I fear that it will be postponed, the "recycled" devices for testing (according to confirmation from the supplier), are set aside precisely for this same reason, the "SC-672"
                      xD ha ha ha xD
                      • gmulvaney
                        • Jan 2024
                        • 1
                        Just tried the CTL swap on a MPC3004 and its EX variant and it was a no-go. Spent way too much time replacing the SOP panel and the USB following the bulletin. How much is a CTL from Hytec with a core swap?
                        • Gift
                          • Mar 2011
                          • 2459
                          PCB prices are insane. It's funny how most companies does their greenwashing campaigns and talk about sustainability but the truth is they aren't interested at all in keeping their products alive. Customer came with an SPC361SF this week and it had a bad operation panel control board - my
