Paper fold on the edged Ricoh 9003
  • Porhuor
    • Feb 2023
    • 30
    Dear all,
    I have a problem with my ricoh 9003 when the paper came out it was folded as in picture.
    I don't know which point that the paper was touching. Do everyone experienced with this problem please kindly instruct to me?
  • anothertech
    • 1771
    Re: Paper fold on the edged Ricoh 9003
    Start by disconnecting the finisher to see if it still does it. Then set it for single sided print with face up delivery to narrow it down more.
      • 37529
      Originally posted by Porhuor
      Dear all,
      [ATTACH=CONFIG]61138[/ATTACH]
      Looks to me like what happens when separation roller starts getting glazed. The so called 1M rollers seldom lat much longer than 800K before the separation starts getting glazed. Normally they are not cleanable unles you have grit cloth.
      • anothertech
        • 1771
        Yeah, I guess I should've said to try running out of all the paper trays also.
        • Porhuor
          • Feb 2023
          • 30
          This machine didn't use finisher. When I try one side print it doesn't have any problem but 2 sides it folded.
          • Porhuor
            • Feb 2023
            • 30
            Not only one tray i tried all paper trays it's same
            • fbkhan3
              • May 2012
              • 421
              Dear all,
              If its right in the middle of the page, check Duplex roller (Driven Reverse Roller).
              • luca72
                • Oct 2017
                • 1784
                Dear all,
                worn or bad separation roller, replace paper feed roller kit of these pickup station
                "I'll be back"
                • amotep
                  • Jul 2018
                  • 1
                  Porhuor,
                  You managed to solve the problem, I have the same problem on the same machine.
                  A greeting.
