Weird vertical lines
  • orientalsniper
    • Aug 2019
    • 8
    [Misc] Weird vertical lines
    Hello all, what could be the cause for these vertical lines?
  • davel
    • Oct 2011
    • 1104
    Re: Weird vertical lines
    Call a trained technician for that machine, whatever it is.
      • 37488
      Something having to do with the Cyan PCDU. Dirty shield glass or doctor blade.
      • anothertech
        • 1769
        Is there a laser slit glass cleaning tool inside the front door? Use it on all colors but concentrate mainly on cyan.
        • luca72
          • Oct 2017
          • 1778
          PCDUs need to be disassembled and cleaned
          "I'll be back"
          • orientalsniper
            • Aug 2019
            • 8
            Thank you, this was it! It was something simple. I even took out the transfer belt which was unnecessary.
