Yellow print on RICOH MPC 6503
  • Exodia-P4
    • Jan 2023
    • 135
    Hello everybody
    I have a problem on a Ricoh MPC 6503, all the color's print get out in yellow (not the white and black print...).
    Yellow print.pdf
    (Toner OEM - colors counter +/- 150k)
    I try to make a colors calibration... failed / power OFF-ON : failed / Change potential sensor : failed
    After that, I try a process control and directly I have an Error SC-370-01 (ITB looks good). I Clean the ID sensor on my ITB and test again, SC-370-01... (history of process control : 21212121 ).
    I Try to initialize TD sensor and it's OK
    It's the second time that we have this problem... Before, I do just a calibration and it was ok...
    Anybody have allready have this problem ???
    Thank you
  • copier tech
    • 8222
    Re: Yellow print on RICOH MPC 6503
    Originally posted by Exodia-P4
    Hello everybody
    [ATTACH]61260[/ATTACH]
    Thank you
    Refer to the service manual for your process control result. As i'm sure you know a successful result should be 11111111
    Most likely you'll have to replace the yellow developer.
    • Exodia-P4
      • Jan 2023
      • 135
      Yes, I already refer to the service manuel... I just would anoter opinion
      • Polo-022
        • Sep 2007
        • 486
        It must be the Yellow Developer Unit. The Toner Density Sensor has failed.
        Replace as required.
        • copier tech
          • 8222
          Could be a faulty ID sensor (front)
          SC370-01 ID sensor calibration error (F)
          • Exodia-P4
            • Jan 2023
            • 135
            I think I have this error because ITB is all yellow (Due tu the yellow PCDU problem)...
              • 37628
              Does the problem occur in both copying and printing, just copying or just printing?
              1. If just copying you most likely have an optics problem.
              2. If just printing it most likely is a board, memory or HDD only used for printing.
              3. If both you are looking at the yellow development unit or the yellow PCU. My vote goes for the PCU. Try cleaning the charge roller. A dirty charge roller = reduced charge on the drum. Reduced charge on the drum = background.
              • copier tech
                • 8222
                He is getting an SC-370-01 error & history of process control : 21212121 so that has nothing to do with the scanner / optics.
                  • 37628
                  Then we go to 3.
                  • bat
                    • Sep 2008
                    • 140
                    This could be a problem with Yellow Potential Sensor. I have seen it on some production printers. No SC Code, just uniform yellow background fill.
                    • Exodia-P4
                      • Jan 2023
                      • 135
                      I miss to say that another technician have changed PCDU completly two weeks ago +/-, and the problem reappear... But the PCDU wasn't new, so it can be the developper...
                      • copier tech
                        • 8222
                        As you have replaced the yellow PCDU & this initially resolved the issue but the fault returns & you get the SC370-01 error I would look at replacing the front ID sensor as per what the service manual recommends. I suspect because the device can't read the patches correctly & process control fails it over tones the yellow.
                        • bat
                          • Sep 2008
                          • 140
                          Potential sensor is not mounted on PCDU, it is above PCDU.
                          • Exodia-P4
                            • Jan 2023
                            • 135
                            Yes I know, already changed too
                            • Exodia-P4
                              • Jan 2023
                              • 135
                              The customer claa me this morning and there is SC 374-04 : ID Sensor Pattern Density Low Error (Y)
