Yellow print on RICOH MPC 6503
  • bat
    • Sep 2008
    • 140
    #16
    Re: Yellow print on RICOH MPC 6503
    Originally posted by Exodia-P4
    I miss to say that another technician have changed PCDU completly two weeks ago +/-, and the problem reappear... But the PCDU wasn't new, so it can be the developper...
    Did he changed the drum?
    • TonerMunkeh
      Professional Moron
      • 3865
      #17
      There's been a problem with the charge bias boards on this model of Charis, maybe that's your next step.
      Hit it.
      • Exodia-P4
        • Jan 2023
        • 135
        #18
        Yes...
        • Exodia-P4
          • Jan 2023
          • 135
          #19
          Hello, I went yesterday to my cutomer, I change completly ITB (with new id sensor), and I clean all TD sensor and all the printer with vaccum cleaner. I make calibration (OK), and process control (OK : 11111111). and the color are beautiful
          • copier tech
            • 8231
            #20
            I suspect, as the error code suggests, the ID sensor (F) was the issue.
            • Exodia-P4
              • Jan 2023
              • 135
              #21
              Yes I hope
              • Brianneoe
                • May 2015
                • 322
                #22
                • Exodia-P4
                  • Jan 2023
                  • 135
                  #23
                  Hello, the problem reapear today
                  • Exodia-P4
                    • Jan 2023
                    • 135
                    #24
                    Hello, I just called Ricoh tehnician support, and He say me that the problem may come from humidity and temperature sensor : The toner density use infos of the humidity and temperature sensor in order to calibrate and make process control.
                    Maybe the copier is too close of the wall...
                    He say me too that the electric card is not at fault because there will be always the problem... and not alternatively...
                    • stani
                      • Jan 2013
                      • 49
                      #25
                      could you solve the problem?
                      Gesendet von meinem Mi 9 SE mit Tapatalk
                      • Exodia-P4
                        • Jan 2023
                        • 135
                        #26
                        I change the developer with a new last week and it's OK... I hope i find the solution
                        • MIGUELMARCHENA
                          • Feb 2018
                          • 197
                          #27
                          Could be a faulty ID sensor (front)
                          SC370-01 ID sensor calibration error (F)
                          A few days ago on an MP C5000 the yellow unit gave a problem, with a yellow background but erasing the location of the ID sensor, I did what the guy described and nothing, then I cleaned all the contacts and it allowed me to take readings. and full image quality.
                          greetings
                          • Bozz
                            • Oct 2014
                            • 16
                            #28
                            Hey mate did you change the whole developer unit or just the yellow dev? Has the issue come back? I have the same issue on the same machine but i am getting yellow potential sensor errors 381-04. I have a sensor dev and dev unit on order.
                            • Exodia-P4
                              • Jan 2023
                              • 135
                              #29
                              Hi, I changed twice... Because empty the developer unit at customer is tiring... So i doing that at my workshop and put the empty developer unit in the copier. After I Put new developper and it all good.
                              I change the potential sensor and it support too
                              • slot
                                • Jul 2008
                                • 341
                                #30
                                every time i have seen this it is the drum potential sensor just change it with another colour to check
